- 14 Jul 2005
- Bristol
Ok, so I'm slowly building my site, using Photoshop to create the image side of things and Textpad to do all of the code (hate using anything other than code - also how I've been taught at uni).
My problem is that I have two <div>s a left one with the main content, and a right one with secondary content...but they either both display in the center of the page, or when I get them in the right positions I use 'float: left/right;' in the css file, which messes up the whole layout of the page...
http://www.finaldecap.com/Concept52/
The above link shows my site with the content in the correct view sections, but as you can see the backing image and the secondary links for the navigation which should be at the bottom are messed up.
http://www.finaldecap.com/Concept5/
The above link shows it how it looks if I am using proper coding in the css...ie not using float, as it's a tricky customer.
The only differnce in the code in both the html and the css is the fact that one page has float and the other doesn't
I don't like to use tables <tr>/<td> etc. If I have to I will, but I'd rather is was a simple site.
If needed I can post the code of the site.
InvG
InvG
