- 12 Jan 2018
How do I fix this? Using ROG Maximus Hero X. I disabled multi-core enhancement in the bios, and uninstalled aisuite. Not sure what else I need to do to get the cpu to run at stock speeds.
Nope not just youIs it just me that's quite alarmed by some combinations of purchase choices and subsequent questions/choices?![]()
With MCE disabled, I've seen the multipliers of all 6 cores rise to x44, but they don't seem to be going past that. Here's some snap shots of what seems to be typical behavior.
https://imgur.com/a/MEmB3
https://imgur.com/a/Jf4Js
https://imgur.com/a/hKQGp
I'm not sure why asking about turbo boost behavior is alarming to you. What I'm seeing seems to run contradictory to intel specs. As to your comment about my purchasing decisions, i7 8700k has a significant increase in performance over previous gens. I'm trying not to OC because the benchmarks I've seen for the 8700k seem to indicate that it runs just fine at stock settings and the power consumption vs performance gains for OCing doesn't seem to be worth it (you get something around a 9% increase in performance for a 30% increase in power consumption).
If anyone knows what's going on - if there's a setting in the bios that's affecting turbo boost functionality, I'd be glad to hear it.
You are right. This is a totally pointless exercise.If you're trying to stop the CPU from overclocking am I missing something or would it have been better just to get an 8700 and save some hassle and money?
^ This.
My 8700 non k will sometimes show all cores at 4.4 - 4.6ghz with light loads, but start an intensive bench that uses the cpu 100% and they will all be at 4.3ghz.
To be honest, it looks like it is working as intended.
amazes me why any enthusiast buys any cpu and runs at stock unless it in a storage or file serverquiet ironic considering his forum name!
amazes me why anyone would buy a 8700k and run it at stock..
amazes me why any enthusiast buys any cpu and runs at stock unless it in a storage or file serverfree extra performance = do not want
