All Arial fonts have gone italic!
2 Aug 2005
This is a really weird problem, for some reason my PC displays the Arial font as italic in Word, Publisher and on the web, but if I look at the font in the fonts folder it's fine. Any ideas how to fix this?
Try re-installing it.
You install it from the File menu in the install fonts folder.
I would delete the old ones first. Also, you don't just have the Arial Italic font do you? There should be a few of them....
Did the trick :)
For some reason there is no edit copy with the fonts, but you can drag the font into another folder, delete the original (from the fonts folder) and then install the font from the copy you dragged out it seems to work.
Such a weird problem.
