All In One Liquid Cooling
That isn't going to deal with a 4.4ghz i7 very well at all. Even the D0 steppings are hot chips, so you need a 120.2 rad and decent waterblock at minimum.
No chance its going to handle that.
ok thanks bradley, I had no knowedge or no experience in water cooling. I will AVOID that one now. I had a talk with my wife about if you (bradley) could help me with 2-4 days of build my case with a best watercooling and neat job with offer you a cash of £150 to do the job for me. You can take my tower case to your house and take your time to build it, test it out and when it ready, I pay you cash £150 in hand of collection. But, my wife metion me a good advice that I should hand you £500 cash to buy all parts of watercooling to setup. Can you (bradley) add all the lists of all parts that need to fit into my antec 1200 case from overclockers co uk and send me the url list of all parts and shopping total cost before I decided to go ahead.
Many thanks Bradley. It ashame that overclockers co uk will not build my tower case of watercooling as they told me to do it yourself.
After a chat with my wife. I have now changed me mind and stick of what I got. I think my cpu cooler is fine afterall.
See here:
i think i shall change this v8 cooler to Thermalright Ultra-120 eXtreme 1366 - Retail
I would get this: http://www.overclockers.co.uk/showproduct.php?prodid=HS-000-PL&groupid=701&catid=57&subcat=
and get this: http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-PL&groupid=701&catid=57&subcat=
and get this two fans (for push-pull) of these:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-004-NC&groupid=701&catid=57&subcat=4
and the temperature will be below 75C for 4.2GHz at 1.300 vcore and 1.640 dram setting with HT enabled and Intel Turbo Boost enabled.
My temperature never go over 75C after 6 hours full load with prime 95 and 2 hours with linx full load.
Here is my snapshot of my full load after 6 hours:
Also get these: http://www.overclockers.co.uk/showpr...d=57&subcat=27
and spread the paste on the cpu processor chip with thin layer and also spread the paste on the cpu cooler plate with a thin layer and attack the cpu cooler into the cpu processor and you're done !
I use push-pull face upward to the top exhaust big fan of my top tower case as I use Antec 1200 case.'
So many thanks bradley for your support, as I had to agree with my wife that I must kept all my redundary money to pay the mortgage. And my pc can cope with 75C with 4.2GHz overclocked and I think 75C is much safer !!!
that kit is very very bad.
looked into it when i decided to go water cooling.
i went for a xspc kit and that is good if you are after a kit.
