All of a sudden “operating system not found”
14 Oct 2007
newcastle
All of a sudden I have got a “ operating system not found” message when booting does anyone have any idea what could have happened and how I can rectify it
Get into the BIOS setup (typically "Del" or "F2") when the system is starting up and see if any HDD is apparent.
Another "issue" I have encountered is that sometimes a system will not boot when you have a USB Memory Stick plugged in.
Could be faulty SSD/HDD but more likely its a corrupted bootloader
if the bios does not show a Windows system in the Boot options most likely its BL issue
Bootloader fix:
Boot up the Recover Windows image (you can create one in windows with ease)
Boot it into the recovery CD -> Go to repair - > Command line ->
bootrec /FixMbr bootrec /FixBoot bootrec /RebuildBcd
this will fix any bootloader issues once done retry booting into windows :)
if you need more instructions
https://www.groovypost.com/howto/fix-windows-10-wont-boot-startup-repair-bootrec/
