- 30 Dec 2003
After doing some Java development I've been messed with various phones checking compatibility... Installed the wrong drivers and wanted to change the drivers... But was having issues with Windows not thinking the ones I wanted to put on were better and keep reverting to the old (incorrect) ones.
Eventually I started removing files from the command prompt, in the inf directory. Just after I'd finished I intended to dir o* to check I'd removed everything I wanted but instead typed del o* - Ouch!!
After quite a while frustrating trying to rectify the situation I considered System Restore. I'd never used it before and actually used to turn it off... Luckily I must have forgotten this time and let it run it's magic and see if it helped... It only went and fixed the problem!!
I'm sure this is old news to a lot of people but anybody like I was before this incident and preferred to disable it: Don't... You never know when you might mess up!
