Alloy FPS - Mechanical Keyboard
28 Sep 2017
The Alloy FPS is exactly what is says, it's a metal plated keyboard that's perfect for FPS players.
It's compact, It's sturdy and when the pressure mounts you don't have to worry about button bashing because this keyboard will carry hard.
The Alloy FPS comes with its own carry case and 8 textured replacement keys for the W,A,S,D and 1-4 which improve grip and look with their reskin too.
In terms of the other features the Alloy FPS comes with a braided USB cable and a handy USB charge point for peripherals, it's not suitable for data transfer however not that you'd need it.
The keyboard has a width of only 442mm making it perfect for gamers on the go or those who value their desk space and can easily slip into it's included carry case for when it's time to move out. It's also a plug in and play model so no need to worry about using it with other rigs.
Interested? Check it out for yourself at: https://www.overclockers.co.uk/hype...gaming-keyboard-cherry-mx-blue-kb-000-hx.html
only blue switches?
Yeah, they manufacture each SKU according to the preferred switch type of the closest market so they can get them to the market that will buy the most, as quickly as possible. Asia and Australia prefer blue switches so they do a blue run first. Then will be brown or red. Once they have manufactured and we have a due date I will list.
