Alloy wheel fitment advice
  • Thread starter Thread starter mk1_salami
  • Start date Start date
mk1_salami
mk1_salami
You probably saw the thread i opened about refurbishing my alloy wheels. I've compelted the spare wheel, but the tyre has a puncture.
I need to know if a 16" clio 172 alloy will fit on my 205 gti 1.9 with 15's
It'll just be a few days, so i'm not fussed about it affecting handling. I'm more concerned about fitment sizes. I'm no expert in this area. Any ideas?
Er isn't the clio fitment 4x100, and the pug fitment 4x108. Centre bore and offset are probably completely wrong also.
Clio 172 - PCD - 4x100, Offset - 35 to 45, Centre Bore - 60.1
Peugeot 205 - PCD - 4x108, Offset - 15 to 25, Centre Bore - 65.1
So no, not a hope in hell.
Thanks GT3. Do you know what general type of wheels that would fit?
For example, ford, vauxhall etc?
Mind if I ask where you got those stats? It's handy stuff too know.
Just Peugeot and Citroen I think.
If you were nearer I would have no problem lending you a full set of Saxo VTR alloys which would be the wrong offset so look a bit daft but would fit ok!
A lot of Ford wheels are 4x108 but the centre bore is smaller on them so I dont think the wheel would physically go on without some form of spacer.
Rochford Tyres online fitment guide.
