I must confess I'm somewhat of a nub when it comes to wheel fittments etc.
I'm looking to replace my current ones and have a few questions if you'd be so kind to answer them.
Firstly, could someone explain what PCD and offset are? I've got a vague idea, but would like it explaining by someone who knows
Secondly, my wheels are currently 4 stud. Does that mean I have to fit 4 stud onto them? Or is there something you can do so that you can get 5 studs on?
Finally, how much of an effect does weight actually have? My current wheels are about 7-8kg each, sans rubber. I've been looking at the Oz Leggera's (15x7) which are about 4.9kg each. Would the saving in weight make much of a difference in the overall handling of the car? It currently weighs about 1040kg.
Many thanks
Many thanks
