Well my alloy wheels turned up today, to be honest I wasn't expecting them to be great as I got them cheap but I was pleasantly surprised, they aren't perfect but are pretty respectible and should smarten my car up once they are fitted.
The tyres were described as "nearly new" and i'm pleased to report that they are! Theres stacks of tread, they can't have done more than 3000 miles at most. To buy the tyres alone would have cost me more than I paid so if I run them until they need new tyres then bin them i'm still quids in
Anyway enough of my burbling- the tyres are Dunlop SP sport 3000 and Firestone Firehawk 700. Both have identical tread depths and I was wondering which were the grippier as they will be put on the back? I think the answer is the Dunlops but I just wanted to check.
Now the downside- One of the Firestones had a screw lodged in the rubber between 2 tread blocks, it was probably 5mm into the rubber. I removed it and it didn't start hissing so i'll take that as a good sign but i'll get the garage to check it out and have all 4 balanced before they fit them.
Finally can anyone tell me what tyre pressure 306 XSi's run as i'll use that as a guide as to what psi to run them at as they are bigger and wider than my current tyres.
Thanks.
Thanks.
