- 4 Feb 2006
- nottingham
Hope someone in here may be able to point out possibly what might be cuasing this.
Over the past 6 months my car has had a history of dropping revs normally to 0,either when changing out of gear and slowing down, normally happens shortly after engaging the clutch. This has been an extremely fustrating as its only happened intermitantly, I have tried what I can to solve this to no avail. -
Different brands of petrol,
air filter is clean,
throttle body has been cleaned,
alturnator belt has been tightened up
battery has been changed.
The car has also just been serviced by a main dailer on a P2 service.
I mensioned the fault to the main dealer, they cleaned the throttle body, at first I thought the problem had gone. After cleaning the throttle body the car only stalls whenever I am pulling up at lights, and not so much at changing gears, although occasionally when moving from 3rd to 4th sometimes revs have gone low. But not enough to stall. Having spent over £250 pounds on servicing and £250 on new tyres and other parts I want to get this sorted once and for all.
To make things harder to diag, the ECU light does not stay on whenever this happens. I had a guy out to check the ECU, this was checked out as working fine. Nissan main dealer also claimed that they checked this as well.
It has been suggested that it may be the Mass airflow filter, I have seen some threads stating that this can be cleaned. Will this make a difference.
I would greatly appreciate a reply from anyone who has either encounted this fault.
The car is a Nissan Almera N16. (Y) Which has just covered 39K, this fault started about 35K and I have been trying to track it down since.
