Well this is something new!
A high TDP capable, low profile CPU cooler with the capability of cooling big configurations easily.
Alpenföhn have smashed it out of the park with this one. This is perhaps the perfect cooler for Small Form Factor chassis.
Alpenföhn Atlas - 200W TDP Premium Twin Heatsink CPU Cooler @ £42.95 inc VAT
The Alpenföhn ATLAS is specially optimized for Mini-ITX / Micro ATX applications. Creating a new class of small form factor heatsinks capable of cooling huge heat output systems in smaller cases.
Featuring asymmetrically offset in tower directions, RAM modules can be easily installed - no matter how high the heatspreader of memory is. In addition, there are no incompatibilities to the PCI Express slot.
A completely new, aerodynamically revised fin geometry works in harmony with the two supplied 92mm Wing Boost 2 extreme performance fans. Furthermore, the minimal convex base plate provides an optimal connection to the CPU ensuring optimum heat conductivity.
A maximum mounting height of just 125mm means enormous flexibility in chassis choice.
Included with the cooler is the High Performance Thermal Compound 'Permafrost'. This completes the high-end package and ensures maximum performance every platform
Aerodynamically optimized design:
Atlas is based on a completely new, aerodynamically optimized design of the aluminum fins.
A special deformation of the slats, the air flow of the first fan bypasses specifically on the 2nd Tower to avoid heat to additional. Simultaneously, the fin design of the 2nd Towers is mirrored arranged to increase the flow rate so as to be able to dissipate the heat from the processor more effectively.
Specification:
- Dimentions: 125x105x140mm
- Weight: 650g
- Heatpipes: 5x6
- Fins: Alloy
- Bottomplate: Copper
- Fans: 92mm Wingboost
- Noise Output: 8-24.3dB(A)
Only £42.95 inc VAT.
ORDER NOW
