Alpenfohn K2 Mount Doom Cooler
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
In case any of you missed this, we recently received delivery of the K2 Cooler from Alpenfohn. There are some reviews below, and to boot, it looks better than the Noctua D14 :)
alphenfohn k2 mount doom cpu cooler (socket lga1156/1155/1366/am2/am2+/am3/am3+/fm1) @ £69.98 inc vat
for ages myths and legends surround one of the scariest mountains on earth. icy winds and heavy snow fall had been the reason all attempts to reach the crest failed …<br>
you might not be surprised that the k2 inspired us to choose the name for our latest creation. by using 8 heatpipes in a twin tower design, dual wing boost configuration and mntal-airflow technology the new alpenföhn k2 reches highest performance at lowest noise.
- twin tower with 8 x 6mm heatpipes
- the new twin tower design can reach best results in noise and performance by using a combination of 2 fans.
- the trapezoid finshape ensures better compatibility with vga coolers by keeping the distance to the pci-x slot
- all contact surfaces between fins, heatpipes and the baseplate are soldered.
heatpipe/baseplate
- the u-shape heatpipes offer a large connection area to the baseplate for a better heat absorption
- by cnc machining the surface of the baseplate is perfectly even and the thermal transfer is optimized.<br>
fins
- k2 is the first cooler to feature the brand new minimized noise transfer at low airflow-technology. - the advanced finstructure influences the airflow through the heatsink to increase the heat transfer to the air.<br>
wing boost 120/140mm dual-combination
- equipped with integrated decoupling elements, wb technology and hd bearing k2 comes with each one 120mm and 140mm wing boost fans.
120mm fan
- fan size: 120x120x25mm
- fan speed: 1500 rpm
- airflow: 108 m³/h
- bearing: hd-bearing(hydraulic bearing)
140mm fan
- size: 140x140x25mm
- fan speed: 1100 rpm
- airflow: 104,7 m³/h
only £69.98 inc vat.
order now
http://www.vortez.net/articles_pages/alpenfoehn_k2_cpu_cooler_review,10.html
and
http://www.madshrimps.be/articles/article/1000248/Alpenfhn-K2-CPU-Cooler-Review/4#axzz1iVBxt1a1
Also remember, it's MUCH quieter than those ALC units.
Oh and a simple email to Alpenfohn will get you the LGA2011 kit for free. Their customer service is on par with Noctua.
