Hi Guys
One of our favourite coolers here at OcUK has just won another award
Alpenföhn Matterhorn Pure Edition which currently carries high praise from the likes of Vortez has just been reviewed over at eTeknix
Link To Review
along with some really detailed pictures of the cooler, there is a lot of closeups of the details.
Alpenföhn Matterhorn Pure Edition CPU Cooler (Socket 775 / 1150 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £29.99 inc VAT
What characterizes a good mid-class CPU cooler…Is it a premium-quality finish, a high performance, a low-noise fan or is it the dead easy mounting in nearly every Midi Tower case?
With our brand-new Matterhorn Pure we combine all these points and offer the ultimate high-end package at a nearly unreasonable low-price. The special trapezoid shaped fins that are placed in a 180° rythm creating two essential advantages:
- Narrow Fin pitch in the center of the heatsink: This feature increases the thermal surface and ensures a higher heat dissipation
- Wide fin pitch at air inlet area: By having a wide fin pitch at the air inlet area the Alpenföhn „Matterhorn" can be run with very low fan speed as the airflow faces less resistance.
Despite that the "Matterhorn" cooler has closed sides. This helps guiding the air through the narrow fin area and offers better mechanical stability
Heatsink Spec:
- Size: 138x123x158mm
- Weight: 657gr
Fan Spec:
- Size: 120x120x25mm
- Rated Voltage: 12 VDC
- Speed: 500 - 1500 RPM
- Airflow: 108 m³/h
- Bearing: HD-Bearing
- Auto Restart: Yes
Only £29.99 inc VAT.
ORDER NOW
Link To Review
eTeknix said:The Alpenfohn Matterhorn Pure is an excellent value for money and high performance cooling solution that is capable of taming all high performance CPUs on the market today, and with high overclocks. Furthermore it is impressively quiet and has solid German build quality emanating throughout the design. I wouldn’t hesitate to recommend the Matterhorn Pure to anyone looking for a low cost entrance into the world of high performance air cooling, though I would encourage consumers to be aware of RAM compatibility issues with high profile RAM modules.
Heatsink Spec:
- Weight: 657gr
Fan Spec:
- Airflow: 108 m³/h
- Auto Restart: Yes
ORDER NOW
