**ALPENFOHN'S NEW BEN NEVIS ADVANCED RGB COOLER**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
The Ben Nevis Advanced is a more powerful version of the normal Ben Nevis cooler in every respect - now in a new Black Edition and with chic RGB lighting. The heat exchanger has been extended with more fins and an additional heatpipe, which significantly improves the cooling performance. The larger and more powerful fan also reduces noise emissions.
Alpenfohn Ben Nevis Advanced Black RGB CPU Cooler - 130mm @ £32.99 inc VAT https://www.overclockers.co.uk/alpe...ced-black-rgb-cpu-cooler-130mm-hs-05b-al.html
Socket Compatibility: 1150 / 1155 / 1156 / 1151 / 1366 / 2011/ 2066 / AM4 / AM2+ / AM3 / FM1 / FM2
The four 6 millimetre thick copper heatpipes are now in direct contact with the CPU, absorbing the heat directly from the processor and then transferring it directly to the countless aluminium fins. This process ensures superb cooling with conventional heat-conducting paste. The asymmetrical design allows all RAM slots to be fully loaded.
The pre-installed 130 mm fan, with PWM functionality, provides a strong air flow of 95,4 m³/h for a fast and efficient dissipation of waste hate. Despite its fast and efficient 150 Watt TDP cooling, the fan is astonishingly quiet due to its conical design and performs at a max volume of 25,8 dB(A) when spinning at a maximum of 1.500 RPM.
In addition to its excellent price/performance ratio, the Ben Nevis Advanced is also outstanding in terms of its enhanced compatibility. With the mounting system it offers simple and safe installation on the 2011(-v3), 2066, 775, 1150, 1151, 1155, 1156, AM4, AM3(+), AM2(+), FM1 and FM2(+) sockets.
As this CPU cooler is attached directly to the retention module of the motherboard without the need for a backplate screw connection, it is fully <b>compatible with the AMD Socket AM4</b>, which was created in 2017 for the AMD Ryzen desktop processors.
With the help of the Shock KILLER POLE the system is also better positioned to absorb sudden movements or while the CPU cooler is being shipped in the system. Furthermore the Shock KILLER POLE also offers more stability to prevent bending of the aluminium fins.
Technical Details:
Dimensions (with fan): 130 x 159 x 74 mm (W x H x D)
Weight (with fan): 630 g
Material: Copper (heatpipes), aluminium (fins, bottom plate)
Heatpipes: 4x Ø 6 mm
Fans: 130 mm PWM (8 - 25,8 dB(A), 500 - 1.500 RPM, max. 95,4 m³/h)
Cooling Performance: 150 W TDP
Connector: 4-Pin-PWM
Compatibility:
AMD: AM2, AM2+, AM3, AM3+, AM4, FM1, FM2, FM2+
Intel: 775, 1150, 1151, 1155, 1156, 2011, 2011-v3, 2066
Bundle:
Thermal paste
Fan brackets
Installation instructions
Only £30.99 inc VAT.
ORDER NOW
ALL ALPENFOHN COOLERS AVAILABLE HERE
Looks like a winner for that price + not too heavy overclocking. Black coating, RGB fan, clears DIMM slots, under 160mm height, four heat-pipes, interesting conical design for fan (even if it turns out to be just a gimmick it's nice to see new designs).
Would be good to see a review comparing cooling/noise performance to Hyper EVO, Quad Lumi and others.
