- 9 Jun 2011
Anyone used this ?
Thanks, Matt,Wanted to, but perhaps a relabel of Junpus DX2
This is the subzero model (A relabled DX1):
Alphacool Subzero Thermal Grease & Phobya NanoGrease Extreme - Review & Comparison
So as some of you requested me to try the Alphacool Subzero Thermal Grease, as well as the Phobya NanoGrease Extreme I thought it is time to test and review ...www.youtube.com
GC-Extreme is probably the best overall for cost and performance:
The BEST Thermal Paste in 2021/2022? Thermal Grizzly Kryonaut Extreme VS KPx VS GC-Extreme
REMEMBER to Watch revisit with new GC-Extreme: https://www.youtube.com/watch?v=99GDvn_UB30&tSo I finally managed to properly test the brand-new Kryonaut Extr...www.youtube.com
I have zero idea, tomorrow I will be turning on my Formd T1 for the first time. If you are having issues, then the 7900X3D I have installed is going to melt.Thanks, Matt,
I've got a question that you might be able to help with. My 7950x3D running on cc0 consistently reaches temperatures of 83°C on two of the cores at peak load, with the package temperature hitting 86°C when cooled by a 420m Arctic II. Interestingly, the other CCD maintains a cooler temperature of around 70°C.
I've reseated the components multiple times, but I'm wondering if this behavior is normal? Any insights would be greatly appreciated.
Hope it goes well !!I have zero idea, tomorrow I will be turning on my Formd T1 for the first time. If you are having issues, then the 7900X3D I have installed is going to melt.
Cool as a cucumber, idle temps are high 20's. I will check out load temps tomorrow, curve optimiser is going to take a while. Cannot be bothered to test anything today. The Asus Strix LC II is the most hideous AIO I have ever owned. Holy **** is the pump loud, can hear it outside the room and lowering to 70% PWM does not do that much.Hope it goes well !!
I ended up getting the Thermal Grizzly Kryonaut Extreme thermal paste, and it surprisingly shaved off 2 degrees Celsius from my temperatures! Although it might sound like a small improvement, it was definitely worth it in my opinion. My highest core temperature now reads 83°C, while the rest of the cores are in the mid-70s, thanks to a -10 curve optimizer.
