Alphacool CPU CAPE KC42-X2
27 Sep 2004
Warrington
Anyone using one of these for cooling dual core optrons or 64x2? If so any good please let me know as Im thinking of replacing my antarctica block. Or is there any other blocks made for dual core in mind
I'm not sure of how good that block is but the best blocks (arguably) are:
1 Storm G5
2 Swiftech Storm
3 Storm G4 and AquaXtreme MP-05
4 Apogee?
5 Nexxos XP
6 Swiftech MCP 6002
7 DD RBX
8 DD TDX
Which of those would be suitable with a Eheim 1048 pump? as I don't really want to change my whole setup. Im I right in thinking some of those blocks require high flow pumps?
The Nexxos XP is good in a low flow loop. It's slighly better than the MCP 6000. The storm blocks are good in all situations.
Ok decided on the Nexxos XP do OCUK do the compression fittings for the block? or are they included with the block as the image shows none attatched. I might as well buy the block from elsewere if I have to buy the fittings elsewhere to.
The Alphacool site says that it is shiped without barbs, (G1/4” (BSPT 1/4") 8/10mm) I would be inclined to go with the Apogee.
