Alphacool Laing DDC-Pump 12V Ultra
Yep that will work fine, bit overkill though if you are just cooling the gfx card. Are you planning on cooling the cpu under water?
Single card, SLI or crossfire ?
I use one with my X2 4400 & X1900XT works very well, quiet little pump too ;)
Rob
will just be for a single x1900xt and maybe the motherboard chipset later on. Most likely with a single 120 mm radiator
The cpu is phase cooled
I would'nt bother with the chipset tbh.Should give you some nice clocks on the X1900XT as well mate ;)
Rob
Meh, with an ultra you might as well - just make sure youre using the top barb as inlet, thats a 25% performance gain right there.
20ft head, cool 2 GPUs, chipset and then itll laugh at you :D
