Alphacool NB-SLI1 Instructions?
11 Nov 2005
Edinburgh/Milan
I just bought this block from OcUK, as its the only way to replace the noisy-ass screamer on my MSI N4 Plat, but it came without instructions - apart from a repeated warnbing not to tighten barbs with a wrench (fat good will it do me, i need to change the compression fittings it came with and it feels like godzilla had a go at them).
Anyone know exactly how this is supposed to be screwed into the mobo, or if I should ask OcUk to send me an instruction booklet? Cant find any info on the net.
Heres the image from their website, i assume you have the bolts/springs/nuts to fit it
D'oh. Yeah, it also came with 2 rubber washers which i assume go on the other side of the mobo.
It's a little flimsy, but it'll do, i guess. :)
