Alphacool VPP655 with Poweradjust2 ?
28 May 2010
London, UK
Can a D5 pump be controlled with a Poweradjust2 USB Ultra(in conjunction with AQ5LT)?
I am thinking of changing my DDC 18W to an Alphacool VPP655 with an aftermarket top. But do these come with a RPM signal line?
I want the AQ5LT to monitor the RPM of the pump but I can't seem to find if Alphacool VPP655 has got a RPM wire or not!
Koolance do a d5 with taq wire, other than that you can solder your own on. Not sure how the poweradjust works but regardless the only way to control the speed on a d5 (apart from using the standard potentiometer) is voltage regulation, the poweradjust will need to be able to handle at least 25w.
