Might not be the most powerful sub bass you've heard, but it'll do the job! What car? Just looked at your signature, Alfa 156? I'd play around with the positioning of the sub in that boot, because it's hard to get decent sound through a saloon without more power.Easily, at 50W RMS per channel, you can bridge that and run a sub no problemMight not be the most powerful sub bass you've heard, but it'll do the job! What car? Just looked at your signature, Alfa 156? I'd play around with the positioning of the sub in that boot, because it's hard to get decent sound through a saloon without more power.
Alfa rather nicely fitted a port tube through the parcel shelf for there own sub system.![]()
Sounds like you'll be fine then![]()
For a small amp like that you shouldn't even need to run large cable, so it should be fairly easy. Don't forget to run the power cable and RCA cables on seperate sides of the car to avoid interference!
Whereas i had terrible whining issues untill i separated the cables on both my old mini, and a corrolla![]()
I'd put my neck on the line and say that is complete tosh.
The power cable carries a DC current and therefore does not contain any current (it's late, I cant remember the exact term) that can interfere with nearby cables. My friend had a very expensive (and I'm talking 2 grand per amp, 3 grand front comps etc) install and he ran his RCAs right next to his power cable without any issues.
