hi guys...
i'm a big fan of textmate i think its really awesome, but there are a couple of changes i'd like to make in the bundles:
1) HTML -> Entities -> Convert Character to Entities
- this shortcut just doesnt work for me, it is supposed to be cmd+& which is assume is cmd+shift+7 but it does nothing, so want to change the shortcut if possible as i use this all the time, but no shortcuts that i set work it ONLY works through the menu
2) next up is HTML tidy, while i find this really useful there is a niggle... whenever you tidy, if looses any element codes like & for example gets converted to just & and • gets converted to • which is no good and actually stops me using the tidy feature...
is it possible to sort these things?
