Alternative to alan keys??
22 May 2010
Minibotpc
Tried fitting the res combo and ek pump 2.2 with the supplier screws and alan key however the key is really brittle and has already rounded itself :(.
Is there a good alternative to using them? I dont think i've tightened the pump to res combo enough...
Well the allen key is completely knackered... I do have a small set of screwdrivers but no idea if it will work till tonight :(.
Theres a little bit of play between the res and the pump, sems secure but i dont want to gamble it
Ahh i wish someone had told me this before i bought the key because i would have gotten a set on the way home :(
I've got this really old Snapon yellow rachet scewdriver and it is fantastic! I literally use it every day and it is probably the most useful thing I've ever owned. You can change the tips, I've got a Mac tools set that allows me to do everything: torx, allen heads and a load of other things I've never seen before. If you regularly do anything with computers or DIY then this is a must-have! I honestly can't say how useful it is!
The model number is SSDMR48.
Thanks! I'll defo look into as i lack any sort of useful tools at moment apart from a mechanics tool box and some smaller screw drivers!
Do you have any kind of grinder to hand ? bench grinder, angle grinder, even a dremel with a grinding stone.
Just grind off the small part of the Allen key you've rounded off.
Its alright, i managed to sort it out. I used the other end of the allen key to screw it in. Pushed it in so it couldnt move and turned quite nicely :).
Thanks for the support all
