Alternative to Bootcamp?
27 Sep 2004
It seems after the release of Leopard, the Boot camp 'beta' ceased to exist. I'm still running os x but would like an alternative to boot camp. Something that allows a dual boot rather than within a window.
A free alternative would be even nicer. :p
Unless you are still running Tiger then Bootcamp is party of leopard and so an upgrade to leopard gets you bootcamp full product.
I though parallels, vmware fusion etc just allowed you to run Windows in a window of your OSX, not boot natively into Windows.
Didn't mean to cause any confusion. I meant I didn't want XP to run within a window, I wanted an option to boot separately....Like boot camp provides.
Didn't realise boot camp was the only available application that provided a dual boot.
Thanks anyway!
What's wrong with Boot Camp? It's free and comes built into Leopard on Intel boxes.
No need for something else...
You can't use Boot Camp at all if you have a raid setup.
You can't partition a non-startup drive and install Boot Camp on one of the partitions.
It needs competition as those are annoying problems.
Fair points. Not exactly what the OP was suggesting however ;)
I'd dearly love to be able to boot XP from an external firewire drive... Got a nice 7k laptop drive here in a caddy ready and waiting...
But on a PC you can't boot from a USB/Firewire/eSATA HD so why on a mac?
TBH I'd make a 20Gb Partition then get a eSATA card + 2.5" enclosure + 7200RPM for everything else and the pagefile... be quicker than a single external HD too.
Intel Macs don't have the legacy crap associated with a PC Clone BIOS - they use EFI. It's certainly possible from the Windows end as I had a friend who reloaded his PC and accidentally installed Windows on his iPod!
I had a similar setup when I first used Boot Camp a couple of years ago - 8Gb OS partition, everything else on the 7k drive via Firewire. Worked OK. eSATA is quick, but the cabling gets messy on an MBP.
