Long story short, managed to get a PS5, which is paired to a LG 4K.
The TV's output are Bluetooth and Optical. The G6 which I use on my PC won't work as USB, only using the Optical, which won't allow me to control the volume using the TV's remote.
The PS5, well... only allows USB connection, but I don't know how to control the volume, unless using the G6's knob.
As I'm reluctant to buy a second headset, as most of the ones I've tried sounded muffed compared to the Beyerdynamics 770Pro 80, and how used to it I'm now, I'm wondering if some gentle soul could enlighten me or suggest a DAC (or any other piece of equipment) that would be of similar performance of the G6 but with a remote control.
I believe connecting it to the TV would be a better option, as this TV is only used for gaming and streaming, I would prefer using the PS5 solely for gaming and use the TV's apps for streaming.
