alternative to MCE
9 Dec 2007
Hants
wanting to use my old nforce2 based box as a media center
spec:
dfi lanparty nforce2
amd barton 2800 (clocked to 2200mhz)
2gb pc3200 ddr
nvidia fx5500
runs XP SP2 like a dream. however..
the copy of XP MCE from the MS download servers once burnt to disk returns an error during setup. MS suggest a faulty CD, tried several different disks with same problem.
tried vista ultimate with MCE, which installs fine upgrading from XP. however since doing a windows update is now stuck in a reboot loop. genius.
so, is there any (free if poss) alternatives to MS MCE?
cheers
Yep there is this amazing free program called GB PVR that I have used for the
last couple of years.
Xp + GB PVR + Nova-t 500 = awesome PVR system
cheers guys.
also looking at mediaportal, anyone rate that?
Mediaportal probably has more bells & whistles but I found it slow and monolithic. Mediaportal II looks more promising but it is not even in beta yet. In comparison what I like about GB-PVR is that it separates the Recording service (windows service in background) and the GUI; seemed more stable and runs well on older hardware.
Both have a very active community, helpful forums and lots of plugins.
