Altiris / Unattend.txt - 2 logical disks
21 Aug 2007
I need a scriptable server 2003 R2 install that creates a C: and D: on say a 60% / 40% split
Does anyone have such a script lying around. Previous company had all the builds scripted like this and need to get this up and running ASAP!
All info greatly appreciated as deadlines are looming....
Ill have a look for you tomorrow at work but I haven't ever used unattend.txt for drive partitioning. What PXE method are you using?
Altiris usually deploys a 2gb fat32 disk image (empty of course) and then grows the partition to whatever you choose. It then performs a convert to NTFS. This is using DOS as the boot method but I am sure WinPE would have a sleeker process. I tend to use DOS as its far, far quicker than WinPE.
