Alu Keyboard on Pc..
26 Jan 2006
Belfast
So I have finally got around getting a Wilress mini keyboard for the iMac...but it was with the intention of putting hte original Keyboard onto my Pc (Xp), no connected up and the fundamentals of it work, however...I was hoping and thinking their must be a way of getting the volumne, play pause and cd eject button to work also....have already installed the BootCamp drivers but didnt really change much TBH.
Any ideas or suggestions?
I suppose you would have to assign it manually some how. OS X does it automatically for you. With Windows I think you have to install some over piece of software to get those to work/do it yourself mentality. :)
Here's how i did it, obtain the bootcamp installer, copy it to hd, delete all the drivers apart from the keyboard ones. Run the installer, you will get the bootcamp icon in the bottom right hand corner but it wont do anything useful, the benefits being you also get the onscreen volume change graphics etc, the downer being the bootcamp exe will take around 30 seconds to load at start and can increase boot time, but you do get complete functionality.
umm id be willing to the that..the re-mapping isnt gett a lot of the keys right TBH.
So I install, which drivers do I need exactly..because I tried installing the aple keyboard drivers in the BootCamp folders and it did nothing...
No, do not install the keyboard drivers. Basically you want the whole bootcamp installer. Delete all the other drivers which do not relate to the keyboard. Then run the main bootcamp installer exe. That should do it :)
