Aluminium Case Cleaning
15 Jun 2008
My second system is in the process of being brought back to life. It lives in a well-used Lian Li PC70 full tower. On the floor of the interior the metal is marked where a cracked barb on a Hydor L30 wept unnoticed for a few days and the small amount of coolant evaporated.
Is there any way I can clean this up? Or just generally is there anyway to clean aluminium - I was wondering about some kind of polishing pad on a Dremel, perhaps?
I've found an answer of sorts for this providing you are wanting to clean up aluminium on the interior of your case and don't want to retain a brushed or whatever finish.
Autosol polish from your local Halfords. It smells worse than a skunk's codpiece while you're applying it but the smell doesn't hang around too much once your done, thankfully.
