Well my Dolomite has been leaking coolant for a while now, suddenly it has got faster so decided it was time for a new radiator. Plus at the same time the clutch master cylinder decided to leak fluid so I was having to top up with fluid ever so often.
First job was taking the bonnet off, which I found to be amazingly easy to do. Then onto the radiator, it looked so rusted, no wonder it was leaking! Wasn’t too bad, only had to take off the horns before it would lift out.
Then onto the clutch master cylinder. Realised I best take the airbox off to give me more room to work with. So that meant the battery had to come out, then I could get the airbox away from the carbs.
Few bolts later, with some plusgas to get those old rusted unions off, here is my master cylinder in bits ready for a clean inside. Looks original there so no surprised the rubber has let go. I just cleaned it through and put on the new rubbers, seals much better now.
Onto the next day now and got a call, less than 24 hours from being dropped off, that my radiator was ready to be picked up. So shot down and picked it up. Impressed with what I got back, was only £80 as well with a 1 year warrenty.
Think I have a dodgey earth now, will have to have a test. Oh and one last pic, Mum came home with paint all over her tyre after driving over wet paint! Had to clean it off her paintwork and its covered all of her arch. Any ideas for getting paint off rubber?
I think she would kill me.
