I’m planning on buying a Linksys RV042 with the view to aggregate the bandwidth supplied from two separate internet connections (supplied via two D-Link DSL300T modems.) There a plenty of dual WAN routers that offer load balancing;
[Small list for anyone interested in doing something similar:
BroDigit NFR3024
Linksys RV016
Linksys RV042
Linksys RV082
Symantec VPN 200
Nexland Pro800
Hawking FR24
Xincom XC-DPG402
Xincom XC-DPG502
Xincom XC-DPG602
OvisLink MN200
HotBrick Firewall VPN 600/2
HotBrick Firewall VPN 1200/2
ZyXel ZyWall 35
ZyXEL ZyWALL 70
Edimax BR-6104K
Xterasys XR-4106
Pheenet BIG-02/4 ]
But I decided on the RV042 because of the flexible balancing allowing my network to aggregate between inbound and outbound. Now, the plan is to supply this with the two internet connections via the two D-Link DSL300T modems as mentioned before; and they are on different phone lines and have a different provider so no problem there.
But the problem is that 3 ports is insufficient for my needs and the 8 port version (RV082) is much more expensive. (The reason it will only be 3 is because I will connect a Belkin Wireless Pre-N router to one port for my wireless network and configure it as a gateway.) For more Ethernet connections I have a D-Link DES-1024D that I use for gaming lans and that has an auto-sensing uplink bridge that hopefully will just work as expansion but I’m not very well versed in the complexities of networking of this kind. So after that long and complicated description of what I will try to do, do you think it will work as I intend?[after the expected hiccups and configurations that will undoubtedly take me a day]
Answers before 5.15pm will be greatly appreciate as I can grab Saturday delivery but most of you have jobs so I’m not expecting it. Cheers for your help guys.
-Will.
BroDigit NFR3024
Linksys RV016
Linksys RV042
Linksys RV082
Symantec VPN 200
Nexland Pro800
Hawking FR24
Xincom XC-DPG402
Xincom XC-DPG502
Xincom XC-DPG602
OvisLink MN200
ZyXel ZyWall 35
ZyXEL ZyWALL 70
Edimax BR-6104K
Xterasys XR-4106
Pheenet BIG-02/4 ]
-Will.
, those are genuine questions
