Am I being thick - Blow torch
The little screw that screws over the vent needs to be either fully open or closed (can't remember off the top of my head). Have you tried moving it?
Most don't have variable vents.
They are hard to light, once lit leave totally level for a minute or two to heat up. Once fully heated it should stay lit and you can start waving it around.
thanks guys, turns out I'm having a thick evening, once I figured it out I screwed the metal bit off to put it away, luckily it occured to me fairly quickly that this had actually punctured the gas canister and I was now leaking gas all over the place. DOH!
:eek::D
