You aren't blind(or at least not on this topic ) there aren't any new OCZ PSUs on OcUK, you could look to Enermax or Tagan(modular) or Seasonic(not modular but consistently rated as one of the best).
Modular PSUs allow you to plug in (to the PSU) the cables you need, and leave out the ones you don't.
It helps keep the case tidier, and can help with the airflow through the case.
The P&PC is very expensive though - and like you say loud. You can buy "reasonable" PSU's for less, which are quiet or silent, like the ones recommended above - they aren't about to cave in on you because they aren't P&PC!
Another vote for the Power and PC 510w SLI, You can specify an option for them to swap the fan out for a quieter version. No ticking or clicking from this PSU.
