- 12 Jan 2009
Since I am only getting around well 30fps or 40 or 60 well its all over the place at times on World of warcraft on the highest settings with a Radeon HD 6870 1gb overclocked am thinking am I bottlenecking my system?
I have an AMD Phenom II X2 555 overclocked to 3.4ghz
8gb DDR3 ram (will only run at 1333mhz even though its 1600mhz have tried everything)
M5A97 Pro motherboard
Gelid cooler for CPU
Corsair TX750 v2 power supply
I bought the parts only around a month ago but I have tried unlocking the cores on the CPU but the pc locks up, I tried only 3 cores but again locks up so I am thinking its only built for 2 cores and the other 2 are bad
So what do you guys think? Is my spec ok or did I pick the wrong cpu?
