I'm looking to build the following spec:
Mobo: Asus P5N32 SLI Premium
CPU: Intel Core 2 Duo E6600
PSU: Corsair HX620 620 Watt
Case: Nexus Breeze Silent
RAM: Corsair TwinX 2GB Kit (2x1GB) PC2-6400 800MHz Dual Channel (will increase to 4Gb when funds permit)
Graphics: GeForce 8800GTS 320MB driving a BenQ FP241W monitor @ 1920x1200
Disk: 2 x Samsung Spin Point SATAII NCQ 500GB fitted internally in 5.25" bays using Nexus Drive-a-Way enclosures
Optical: Sony AW-G170AB2
Other bits from my old rig: 2 x Freecom 500Gb external USB drives, Pinnacle 350i DVB/TV card and a Creative SoundBlaster X-FI Xtreme Music
I've used a Nexus Breeze case before and it's beautifully made and whisper quiet, but that was a fairly modest AMD XP2800 system with a 6600 card. My concern is that the Nexus case only has a single 120mm intake fan at the bottom plus the PSU exhaust fan, with no other vents to speak of so I could end up barbequing the graphics card, CPU and disk drives! The alternative is the Antec P180 case which has three fans + the PSU one, although I'm not too keen on the wiring issues with having the PSU at the bottom of the case. I really am looking for a quiet case though, but I don't want to go down the water cooling route.
Was going to use a Hiper 600W PSU but have been seeing reports about them dying too often. The Nexus case comes with its own 500W PSU but I understand that at least a 600W PSU is recommended for a 8800GTS setup.
I'm only looking to use the Creative X-FI card as it's lying around and I figure it would have the edge on the built-in sound on the Asus mobo, not sure if that's correct tho.
Any other thoughts on whether this is well matched setup? I'm looking to use it as a solid games machine plus as a high-end database machine [SQL Server, Helium MM etc.] running Vista Ultimate (when the bugs are worked out!) that will last me 2-3 years.
