Am i deaf??
23 Oct 2002
Norwich
Have finally built my sugo-01 [thanks for the great case Tute] with a G33M-DS2R 'board but i can't get any sound out. I have NOT connected the front sound bits.
Help please.
pugged the speakers in, turned them on etc ;)
drivers, have you installed the drivers, configured the os to make use of the onboard sound card, made sure os sound is not muted etc.
all you need to do is wire up the front sound as shown in this diagram blow
then jump into the Bios and check the onboard sound is enabled
it should be listed in the Integrated Peripherals> Azalia Codec
then install the motherboard sound drivers
http://www.gigabyte.com.tw/Support/Motherboard/Driver_DownloadFile.aspx?FileType=Driver&FileID=837
note some cases don't use mic power so if there isnt 1 its ok
i hope that helps you to get your front sound working
