Am I doing something wrong? (6300)
8 Nov 2006
Hey everyone just got a DS3, 6300 and 1gb Geil 6400 built it all up and have decided to start overclocknig...I followed a guide on the internet and the first attempt is at 2.32Ghz with an Idle temp of about 45oC and a full load of 51oC I have an Arctic Cooling Freezer 7 Pro and I was just wondering if there was something wrong as this temp seem a little bit high and means ill probably not able to go any higher...Could someone tell me if maybe I havent fitted the cooler correctly or if this is just normal? :( was hoping to go abit fast tbh...
Thanks Everyone
Simon
Heres a pic of current settings (sorry if somethings not open that you want to see)
Clicky Here
How did you figure the 51oc was high? seems perfectly fine for full load, the idle temp does look a little hight though... don't suppose you're in a hot room?
actually yes is was quite hot...had an ultra powerful bulb in and i think that has played a major part...Ok then how high do you think I can go temp wise before stopping?
I wouldn't be comfortable over 60 preferably ... The processor's rated for 65'c max, although if you hit 65 it won't die instantly - it's just probably not good for it :p
Its very interesting...was at 2.2Ghz then I just thought "aww well stick it up just to see what temp it goes to" so I was expecting like 60oC but it was the exact same temp as before, steady at 51oC full load and im on 2.55Ghz lol gonna keep going :p gonna try 375FBS which is 2.62Ghz and keep working at it...just out of curiousity does everything look right on my CPU-Z mem wise and stuff?
If you are stressing both cores 100% then 51c is still good. Most people wont normally do that everyday anyway.
I think rmclock will show throttling
