Im on the verge of loosing my Custom Build virginity and im bricking it that im making the right choice so looking for some pre-purchase assurance or better advice
Ok my current spec is
Cosmos S coolermaster case.
Corsair Gold Series AX850 psu
Asus P5w DHDeluxe mobo.
Q6600 quad running at 3ghz with arctic 7 cooler
2gb corsair 800mhz ram,
x1900xt 512mb gfx card with accelero 2 cooler
Creative labs xfi sound card
Gaming wise im mad for TF2 which is cpu heavy, im also enjoying Crysis, total shogun 2 and will probs get into the cod and bf3 titles too soon enough.
Other apps ill use are for doing video converions/encoding although gaming is my priority.
Ok heres whats sitting in checkout ready for purchase and what ill keep from my old rig above
Cosmos S case (from rig above)
Corsair Gold Series AX850 (from rig above)
**NEW components**
ASUS P8Z68-V PRO/GEN3 Intel Z68 (REV B3) Socket 1155 DDR3 PCI-Express 3 Motherboard
Intel Core i5-2500K 3.30GHz retail version
Thermalright Silver Arrow cooler for overclock in future
Crucial m4 64GB SSD (ill get more storage later)
G-skill Ripjaws X ram....2 x 4gb ( I want the blue ones to match colours on mobo but not sure which timings/model to get, Also they are only 40mm high so will clear the CPU cooler)
So at the moment Its gonna cost me around £600
I still need a gfx card but was holding out as the 7000 series is coming out so hopefully the 69xx will drop
I have the option of overclocked motherboard bundles with cpu, ram, cooler and mobo for much cheaper than the components im using......Am I being overkill with my build in a way that i would not see any real time benefit or would I be better just getting a pre-overclocked rig and with the money i save put it towards a gfx card
cheers in advance for any input
**NEW components**
