Am i overclocking correctly ?
20 Nov 2006
My computer specs are in my siggy. Basically i want to know if im getting the most out of pc whilst staying within safe limits. Ive overclocked my cpu to 3.2 and the memory is running at 800MHZ. I havent altered the timings or anything as i dont know what im doing with that.
seems ok to me mate. you could get a little more no doubt out of your CPU to maybe 3.5 if you pc is stable thou and fast anuff for your needs why bother. ??
Looks fine, damn my E6600 must be the worse chip in history ... :(
Just make sure its 8+ hours Orthos stable and temps stay 70c whilst running Orthos and everything all be fine.
You have my exact spec as myself apart from the gfx
I have 3.4ghz no probs with temps although my volts are higher on cpu and memory so i may try bringing mine down a little
