I have recently built my first watercooling rig, apart from trying to fit a triple rad into a tiny case everything went smoothly.
The reason I am making this post is that when i added the water I just added regular tap water with about 1/10 VW antifreeze. I did read that you were supposed to use De-Ionised water but I was too impatient to wait so used regular water. I have been reading some horror stories of green gunk and destroyed fittings and blocks.
Should I rinse the system and do it correctly with de ionised water or will it be okay as it is? It's been about 4 weeks and the water is still like the day I put it in if that helps
