- 11 May 2007
I have a matched pair of TWIN2X2048-5400C4 in the system below. I have it running at the following
http://www.corsair.com/_datasheets/TWIN2X2048-5400C4.pdf
It says SPD is programmed for 4-4-4-12 but bios sets it to 5-5-5-15???
Frequency: 333
FSB
ram 1:1
CAS: 5
RCD:5
RASP:5
Cycle time:15
Command rate: 2T
Should I be running this at 4,4,4,12?
Oh and at what voltage should I run it - 1.8V, 2.0V or 2.1V?
Thanks
OCZ GameXStream 700 Watts
Intel Core 2 Duo E4300 1.8GHz running at 3Ghz
Gigabyte GA-P35-DS3P Rev 1.0
Sapphire X1950Pro 256MB
2 x Raid Seagate 160GB 7200.10
1 x Seagate 7200.10 320GB
2 x Corsair (CM2X1024-5400C4) Twin2X Matched Memory Pair
1 x Lite-on 16 X DVD-ROM SHD-16P1S
1 x Lite-on DVD-Writer SHM-165P6S
Arctic Cooling Freezer 7 Pro
CASE ASONIC XCLIO Server case 5X5.25 6X3.5 2xfloppy
Microsoft Windows Vista Home Premium x32Bit
Frequency: 333
FSB
CAS: 5
RCD:5
RASP:5
Cycle time:15
Command rate: 2T
Thanks
