am2 + 2t on 4 sticks?
13 Dec 2003
UK
Hi there, im looking to use 4 x 512mb sticks of ddr2 with an am2 setup, i was wondering if this is fine to run at 1t command rate or will i be stuck at 2t like the 939 counterpart. I had a quick search here without success.
many thanks
I don't believe this has been mentioned yet actually, I'd be interested to know aswell.
<maddness> said:
thats odd, im running 4 x 512s on this board and it works fine at 1T :D
im @ ddr 400 though
Ah, when i next reboot i will give that a try. Did you try it at DDR 533 or 667 at all?
Well 1T @ DDR 667 and the system wouldnt even come on, 1T @ DDR 533 and the system came on for a second and went Beeeeep Beep Beep and rebooted, but at 1T @ DDR 400 its boots fine.
Just going to bench to see if DDR 400 @ 1T is quicker or DDR 667 @ 2T is quicker.
Well doing a quick 3dm01se run reveals that at DDR 667 2T i get 23500, and at DDR 400 1T i get 24453. So 1T is quicker.
