AM2 motherboard advice
15 Nov 2002
Colchester
Im building two machines for a friend who wants gaming systems for himself and his son.
I am leaning towards an Athlon 64 4200 Dual Core 2.2GHz 512kb L2 cache AM2, 2gb of compatible ram for each machine (probably the cheapest going), an X1800 of some variety and haven not decided on disks yet.
The problem I have is that I'm stuck when looking at motherboards - the last time I bought a full size motherboard it was the NF7s that was king and everyone including myself was able to reccomend it. Primary needs now are onboard sound and lan, decent graphics compatability - sli might be nice but not essential as I would rather spend his money on one decent graphics card - and finally something that is stable. He will not be overclocking and knows little about hardware so the more stable the board is the less hasstle for me :)
So whats the board of choice these days for all the AMD AM2 users out there?
Hamoodii said:
if you haven bought the parts and it isnt too late, get a conroe, much betterr value for money!
when I've looked online it seemed the intel chips were a lot more expensive than the AMD ones? Also if I was going to go the intel route - what motherboard?
wizardmaxx said:
E6300 - £115 outperforms the 4600x2 - £160
Best value for money boards imo - Gigabyte.
Hmm, can you justify that comment about the gigabyte boards? It seems to me from my reading that they are very fussy about what ram they use!
I want an easy life so "stable as a table" is the name of the game not overclocking
Anymore suggestions for either AM2 or 775 boards?
Had a msi before onto gigabyte now ... hence opinion. For around £100 very difficult to match gigabyte afa stable as a table compared to msi. rest of manuf tend to be either more expensive or no namers for what u getting. Memory... thats always an issue, but to settle issue DS4, default volts at 1.8v and Geil, recommended volts at 2.1, boots no prob on f2 bios that in stock.
if you go am2 (doubt it) but msi are great motherboards for it,ive built 2 am2 systems with a k9n neo and another msi am2 mobo and they both work perfectly no crashing, no install problems at all.
