I made a Spec post at the beginning of the month but now the 5850 is out i've had a change of thought. Gona be gaming/overclocking CPU and wanted a cool system with good quality. Now my budget is £1000 but it would be nice to only spend around £900.
I'd like some feedback on these 3 builds which i have been looking at. Any advice on better cooling or case etc?
Intel 1366 i7 920 D0:
GPU -| XFX ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card
Case -| Coolermaster HAF 922 Case - Black (No PSU)
HDD -| Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM
Optical Drive -| Samsung SH-S223B/BEBE 22x DVD±RW SATA
Case Fans -| 3 x Scythe Kaze Jyuni 1900RPM Slip Stream 120mm Fan (1 to be used with CPU Cooler)
CPU -| Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz
MOBO -| Asus P6T Intel X58
RAM -| Patriot Viper 6GB (3x2GB) DDR3 PC3-12800 (1600MHz) Low Latency Tri-Channel
PSU -| Corsair TX 850W ATX SLI Compliant Power Supply
CPU Cooler -| Corsair H50 High-Performance CPU Watercooler (Socket LGA775/1366)
TOTAL: £1,020
Intel 1156 i5 750:
CPU -| Intel Core i5 750 2.66Ghz (Lynnfield)
MOBO -| MSI P55-GD65 Intel P55 (Socket 1156) DDR3 Motherboard
RAM -| OCZ Platinum 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit
CPU Cooler -| Zalman CNPS10X Extreme CPU Cooler
TOTAL: £920
AMD AM3 X4 PII 965 BE:
CPU -| AMD Phenom II X4 Quad Core 965 Black Edition 3.40GHz
MOBO -| Gigabyte GA-MA790FXT-UD5P (Socket AM3)
RAM -| Patriot G Series AMD 4GB (2x2GB) PC3-12800 1600MHz Dual Channel
CPU Cooler -| Thermalright Ultra-120 Extreme Rev.C
TOTAL: £890
Good thing about the AMD setup over 1156 is the 16x16 PCI slots for xfire if i wanted to get another 5850 sometime in the future. I know the i5 and X4 965 are pretty neck n neck though. £100+ more for Tripple channel, HyperThreading & SLi & Xfire support if i went 1366, worth it?
TOTAL: £1,020
Intel 1156 i5 750:
TOTAL: £920
TOTAL: £890
