AM3 800 with sli
31 Mar 2006
can anyone give me any help with finding a good quality AM3 MB which will run SLI all I can find is crossfire boards at OC's.
will be using a AMD Phenom II X4 Quad Core 955 Black Edition 3.20GHz
Thanks
There are s775 boards using Nvidia Nforce chipsets like the 680i, 750i and 780i, 790i. But to be honest - they are all awful compared to the intel equivalent chipsets like the P35 (the one you have at the minute) and P45.
Are you needings SLI as you plan to add second GTX 260 to your Q6600 rig?
yes that was the plan, but I cant afford to upgrade to i3 i5 i7 as I am getting the second gtx260 card for free.
and as the Q6600 is such a good proc I would have like to keep it untill I can save the money to upgrade everything, if I was to sell my system now and then go over to a AMD Phenom II X4 Quad Core 955 Black Edition 3.20GHz and crossfire MB.
how much could I sell Abit ip35pro q6600 8gig mem and a gtx260 I have all the boxes and it would look as new would >£350 and I would add the creative G550W speakers for £70 still in box never used. I was just looking at the price of q6600 the lowest OEM £130 boxed with heatsink fan £219 mine happens to be excellent OC I did buy from OC uk because it was so clockerble, I might just sell the gtx260 * 2 and get 2 ati 5770 crossfire on my system?
