AM3 bracket work on AM4?
7 Jan 2009
I have a H60 Corsair AIO,It appears to have a AMD bracket but i think its AM3? will it work on AM4?
Was previusly using Intel and have for many years so i have no clue,cheers.
hmm not so sure i have it mounted,thought id try see if it fitted and it does just clips onto the existing AM4 mounting thing the board uses for the stock cooler :)
Not sure if its because i have the H60I or maybe V2 not sure i dont think its the first generation of H60 think its a later model.
Been thinking of upgrading to something more beefy though like a 360 rad as my case supports it.
If the cooler uses the stock amd mountings (The black plastic clip mounts on your board) it will fit.
If it uses a custom backplate & custom mounting system it won't fit as the hole spacing is different.
(But you already know this LOL).
