AM3 Cooler Retention Bracket
23 Jul 2011
Hi Guys,
I was wondering if you guys could help me, I'm trying to fix a PC for a family member and what I've found is that the retaining clips for the heatsink (AMD socket AM3) have snapped.
Does anyone do replacement brackets or failing that could anyone suggest a cheap aftermarket cooler which screws through to a backplate. Preferably cheap as possible!
Thanks!
Is this the plastic retention piece that fixes to the motherboard with 4 screws?
If yes, send me a trust message. I may have one.
