AM3 Cooler
13 May 2009
Glasgow
Hi there. Does anyone know of an AM3 cooler that WILL NOT cover any of the dimm slots or at least allow for all four slots to be occupied on the motherboard? Any help will be great, thanks.
You will prob find most tower coolers will cover at least one slot with a fan on push, however normal height rams tends to fit fine even if the cooler does cover the slot, might be worth thinking if you going to get normal or high level lvl ram then choose you cooler after as you may have more choice
Well I'm planning on using 8Gb of Crucial Ballistix Tracer in the form of 4x 2Gb sticks. For the CPU cooler I'm looking at the new Zalman CNPS10X.
I'm currently using an Scythe Orochi on an MSI 790FX-GD70, and all four slots are available. =)
Edit: -Can't get the case side on, though.
