AM3+ cooler.
29 Feb 2004
I need to replace my hyper 212+ as it's not up to the task of cooling my 955.
Currently my x4 955 is running 3.8GHZ @ 1.488V, which the 212+ can just about handle. I'd also like to up the cpu-nb from stock to 2400/2600mhz, but together the 212+ cannot handle it and it's getting too hot :(. Room can get a little warm in summer, so I'd like something with enough cooling capacity that I don't have to take the overclock off in summer :).
I'm using kingston hyper X grey, which isn't a high profile ram, so clearance shouldn't be an issue. Board I use is a sabertooth 990fx, don't think the heatsinks on it should cause issue, but not sure. Case is a cm690 II, and max height of cooler according to coolermaster is 177mm
Budget is up to £100.
Should have added I want pwm fans, I simply assumed high end coolers would use them. Dh-14 is out because of it using 3 pin fans. Sabertooth manual does not say you can switch the to voltage control, it might switch automatically if a 3pin fan is plugged in, but I'm not paying £60+ to find out.
So that leaves just the Phanteks PH-TC14PE, which is 3pin, but they released a pwm adapter that comes with new shipments or you can request one for free or the k2.
Just have to decide now :), but at least I have a starting point to look at reviews etc :).
Thanks for the suggestions.
After a lot of reading today. Think I'll go for the K2, as across most reviews it seems it's within 1-2C of the phantek, yet is £10 cheaper :) and a lot of the reviews seem to praise it's build quality as well :).
Hi i have the sabertooth, if you use a 3 pin fan on the cpu headers it will not adjust the fan speed only 4 pin fans work. The other headers on the board will adjust speed with 3 pins no problem :)
K2 comes with pwm fans :), but it's useful info to know for future reference, so thanks :).
