- 3 Jan 2010
Plan on getting an AMD build (maybe i5 if it goes **** up) so checked reviews of the phenom 2 quad core 955 and saw a few saying it was noisy and gets hot. I'm planning on getting a Haf 922 case which would have this cooling
- Front Cooling: 1x RED 200mm fan (700RPM)
- Rear Cooling: 1x 120mm fan (1200RPM)
- Top Cooling: 1x 200mm fan (700RPM)
- Bottom Cooling: 1x 120mm fan (Zalman ZM-F3 120mm Silent Case Fan )
http://www.overclockers.co.uk/showproduct.php?prodid=FG-002-ZA&groupid=701&catid=57&subcat=4
Would I need a cpu cooler to run it quietly? I wouldn't overclock it other than to maybe 3.5ghz down the line and other than that I'd just have a cool running vapor-x 5770, ram a 1tb hard drive and that's it pretty much. No sound card and silent 700w power supply.
So either try and answer if I'd need any more cooling or recommend a good CPU cooler for AM3 please. Thanks very much
